CFX4: How to write user data to dump file?
Old   July 3, 2003, 12:34
Default CFX4: How to write user data to dump file?
Min-Hua Wang
Does anyone has experiece to use CFX-4 and write data back to dump file and display the user-data via CFX4-view or fieldview? The user-data were generated from a wall -patch and was expected to put on that patch again.
Thanks a lot,
MHW
Old   July 11, 2003, 12:29
Default Re: CFX4: How to write user data to dump file?
John
I have not tried to display the data, but you may put additional information into the dump file through the use of the user routine USRDMP.
If the dump file created is then to be used for a restart, USRRD must also be coded to read in the user defined sections of the dump file.
John
Old   July 16, 2003, 20:38
jeff
Min-Hua,
I think what you want to do is allow one of the post processors to display user calculated data. To do this, create a user scalar name starting with USRD (i.e. USRD_my_variable). In your FORTRAN, store your values in the USRD variable at the appropriate locations. This variable will then be stored in the dump file automatically and picked up for plotting in any of the post processors.
If you only need internal fluid cell values, use a USRDCC variable and just set values at cell centers. If you need discreet values at walls and boundary nodes, use a USRD variable but you have to set all the boundary nodes explicitely in your FORTRAN.
Jeff
Old   July 17, 2003, 20:49
Min-Hua Wang
Hi, Jeff:
The problem is which user subroutine should I use. I have tried usrtrn.f. I only need to display data on wall boundary nodes.
Thanks
MHW
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
A problme to write data file with Tecplot Kai Yan Tecplot 4 October 30, 2007 13:44
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
