July 31, 2003, 23:42 |
Momentum source value
Hello all,
Could anybody Explain how to guess the momentum source value in a tube please. I'm simulaing the flow in an open end tube which has the momentum source inside. I expect 0.1 m/s velocity at the position adding the momentum . I know the cross section area of the tube and the volume of the 3D region of the source and the unit of the momentum source is kg/m^-2s^-2. Does any body have an idea how to guess it ( equation and method ) I'm looking forward to hear the kindly help soon, @T_T@ Thank you in advance. Jackie |
August 1, 2003, 15:20 |
Re: Momentum source value
Hi Jackie,
The momentum source basically specifies a pressure gradient, however you can modify modify it to get a specific speed. The following settings will do the trick: MOMENTUM SOURCE: Momentum Source X Component = -C*(u-uspec) Momentum Source Y Component = -C*(v-vspec) Momentum Source Z Component = -C*(w-wspec) Momentum Source Coefficient = -C END where C is a very large number and uspec, vspec, and wspec, are the specified velocities. Regards, Robin |
August 1, 2003, 15:57 |
How could I know C value Robin.
Jackie, |
August 2, 2003, 10:01 |
The actual value does not matter, it just has to be a big number.
Robin |
August 3, 2003, 10:07 |
Thank you very much Robin.
Jackie |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
