Momentum source value
Like Tree1Likes
  • 1 Post By Jackie
Old   July 31, 2003, 23:42
Default Momentum source value
Jackie
Hello all,
Could anybody Explain how to guess the momentum source value in a tube please.
I'm simulaing the flow in an open end tube which has the momentum source inside. I expect 0.1 m/s velocity at the position adding the momentum . I know the cross section area of the tube and the volume of the 3D region of the source and the unit of the momentum source is kg/m^-2s^-2. Does any body have an idea how to guess it ( equation and method )
I'm looking forward to hear the kindly help soon, @T_T@
Thank you in advance.
Jackie
soheil_r7 likes this.
Old   August 1, 2003, 15:20
Default Re: Momentum source value
Robin
Hi Jackie,
The momentum source basically specifies a pressure gradient, however you can modify modify it to get a specific speed.
The following settings will do the trick:
MOMENTUM SOURCE:
Momentum Source X Component = -C*(u-uspec)
Momentum Source Y Component = -C*(v-vspec)
Momentum Source Z Component = -C*(w-wspec)
Momentum Source Coefficient = -C END
where C is a very large number and uspec, vspec, and wspec, are the specified velocities.
Regards, Robin
Old   August 1, 2003, 15:57
Jackie
How could I know C value Robin.
Jackie,
Old   August 2, 2003, 10:01
Robin
The actual value does not matter, it just has to be a big number.
Robin
Old   August 3, 2003, 10:07
Jackie
Thank you very much Robin.
Jackie
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
