how to visualise the total pressure
Old   August 14, 2003, 20:37
Default how to visualise the total pressure
Anicorl
Hello, everyone,
When I simulate the flow in a single square duct, in the CFX-post, the only pressure can be visual, but the total pressure cannot. I use CFX5.5 version.
To visualise the total pressure, how to treat with this case? Would you mind telling me your arrangement? It may give me some ideas to solve my problem. Thanks for your response.
Anicorl
Old   August 15, 2003, 03:38
Default Re: how to visualise the total pressure
Louwrens
You can visualise total pressure same way as static pressure... instead of clicking on the down arrow to get the variable drop-down list, click on the three dots just to the right and you'll get a list of all the available variables. You'll find total pressure in that list.
Louwrens
Old   August 16, 2003, 06:44
Anicorl
Yes, I have done as you said. I can find there are only pressure, pressure gradient X, pressure gradient Y and pressure gradient Z in the list of available. But I still cann't find total pressure in that list.
Anicorl
Old   August 16, 2003, 10:08
Louwrens
Then I dont know, its supposed to be there! You did look right at the bottom of the list, at "T" for total pressure? Because the list is sorted alphabetically and total pressure is not located with the other pressure variables...
Else you maybe got the special total pressure-less version of CFX 5.5.1 (at a discounted price?) ;-)
Old   August 17, 2003, 18:45
Total pressure will not always be there if you are looking at a backup file (from a steady state run) or a transient output (from a transient file). In these cases, the file only contains the variables you specify. The final result file should have all variables, including Total Pressure (as Louwrens said).
Regards, Glenn
Old   August 18, 2003, 02:25
Louwrens
Ah... everyday we learn something new ;-)
Old   August 18, 2003, 04:25
Bart Prast
If you're running a general fluid case in CFX 5.5.1 you will not get total pressure (only when running ideal gas), as the relation for a general fluid for the total pressure is not trivial anymore (as it is for ideal gas). CFX 5.6 has more capabilities in this direction. So if you want P0 in 5.5.1 run with an ideal gas.
Old   August 18, 2003, 09:13
Anicorl
Thank everyone very much!
Old   August 25, 2003, 17:06
Robin
All,
Total Pressure is always there (look harder), even in a backup file (if you choose the full backup option, which is the usual). The calculation of total pressure is different for compressible and incompressible flow but for a general, incompressible fluid, the calculation is simple (Pstatic + Pdynamic).
Robin
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
Static Pressure, Total Pressure ufechner FloEFD, FloWorks & FloTHERM 5 March 2, 2015 07:56
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Total pressure value as boundary condition findviru STAR-CCM+ 2 January 7, 2011 09:08
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
