August 16, 2003, 02:25 |
boundry of two phase flow
hi,all I have trouble to define an outlet of gas-solid two phase flow in CFX44, where gas phase can pass through while solid phase can't. How can i achieve this. I am using an euler-euler solution.
September 12, 2003, 23:39 |
Re: boundry of two phase flow
Youngan,
You can't inhibit one of the phases at an outlet. However, there is something in CFX-4.4 called a degassing boundary. It was originally intended to remove bubbles from the surface of a liquid tank. The tank surface is defined as a "wall" and the bubbles incident on the wall are removed with a source term while the liquid remains. There's no reason this can't be used for your gas-solid flow. I think that the command file implementation of the degassing boundary removes phase #2, so you'll have to make sure your solids are phase #1 and that the gas is phase #2. What do you plan to do with the solids build up at the exit? This might present a problem. Jeff |
gas-liquid 2 phase flow in microchannels using VoF | LyngHoo | FLUENT | 1 | November 13, 2012 19:01 |
Two Phase Darcy flow with gravity -> problem | Cyp | OpenFOAM Programming & Development | 0 | November 17, 2010 07:58 |
two phase flow + ice phase and breaking | soeren87 | OpenFOAM Running, Solving & CFD | 0 | September 19, 2010 10:20 |
Two phase flow in a distributor | Mohsin | FLUENT | 5 | May 24, 2010 02:57 |
low speed compressible two phase flow?? | cat | CFX | 0 | November 15, 2005 07:59 |
