For the turbomachinery guys
Old   August 29, 2003, 06:32
Default For the turbomachinery guys
Louwrens
I'm gonna be simulating a 3 stage compressor in 5.6. I've worked through the axial stator-rotor tutorial, which has explained the general stuff, but in that case both the stator and the rotor were shrouded. In my problem both are unshrouded, ie I've got a stationary wall just above the tip of the (rotating) compressor blade, and the rotating hub of the compressor just below the tip of the stator blade. If I want to model the relative motion between the blade and the wall, does this imply that I have to model the tip clearance between the blade and the wall? That would obviously lead to very flat elements in that region. I've never CFD'd turbomachinery before so any tips would be really welcome.
Cheers
Louwrens
Old   October 5, 2003, 18:52
Default Re: For the turbomachinery guys
Martin Bowers
You really should model the tip gaps. You could attempt to ignore the tip gap and set the appropriate wall BC to rotating, but that's definitely not standard practice in any of the work I've done.
Turbomachinery at OpenFOAM Workshop Milan 2008 hani OpenFOAM 0 March 21, 2008 02:33
best CFD software for turbomachinery sam Main CFD Forum 10 April 13, 2007 15:42
BEM in Turbomachinery seckin Main CFD Forum 0 February 19, 2002 18:55
GAMBIT and Turbomachinery tom Main CFD Forum 6 October 21, 1999 09:50
ERCOFTAC Seminar and Workshop on TURBOMACHINERY FLOW PREDICTIONS VII Stephane AUBERT Main CFD Forum 1 October 9, 1998 16:37
