CFX with Fieldview
Old   November 6, 2003, 09:39
Default CFX with Fieldview
Ogbeni
I am trying to use Fieldview to post process CFX 5.5.1 output, but I wonder what format I must save my output from CFX, any one with experience using field view please help.
Old   November 6, 2003, 17:43
Default Re: CFX with Fieldview
Neale
You need to use the fieldview export. This is available in the solver manager.
Neale
Old   November 13, 2003, 09:18
Ogbeni
Neale, I tried loading the *.res file from the solver manager but I could not,hence I could not save it ti fieldview format. Ant suggestions ?
Old   November 19, 2003, 11:18
Johnson
Obgeni
If you run ExportFieldView.exe (found in ?CFX-5_INST_DIR?/bin/5.6/?OS?) from the command line with no arguments you'll see all the options available for converting a res file to an fv file.
Regards,
Johnson
Old   November 21, 2003, 10:02
Ogbeni
Thanks Johnson
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
