Having problem with turbulent flow over a forward facing step
Old   August 31, 2015, 17:10
Default Having problem with turbulent flow over a forward facing step
eskadran is on a distinguished road
I am using Ansys CFX for simulating a turbulent flow over a forward facing step. The Reynolds number is around 10000 and the step height is 9 mm. I did the grid study and the boundary conditions that I used are velocity at the inlet and zero static pressure at the outlet and no slip at the walls. I am comparing the performance of two different turbulence models (k-e, sst). The problem is that k-e can predict the length of the recirculation region at the top of the step with a vary good agreement with experimental results while SST predicts the length of the recirculation region twice the experimental results. I've read that k-e has a problem with separating and reattaching flows and cannot predict it well and I'm confused. Please let me know about your opinion in this regard.
Thanks
eskadran is offline   Reply With Quote
problem with DNS turbulent channel flow huangxianbei OpenFOAM Running, Solving & CFD 4 March 4, 2014 23:39
Reasonable Time Step for Turbulent Flow Simulation MOHAMMAD67 OpenFOAM Running, Solving & CFD 20 April 18, 2012 08:11
backward facing step flow student Main CFD Forum 4 January 4, 2007 11:55
Specfying Turbulent boundary-backward-facing step Ben Sellars FLUENT 1 December 13, 2006 07:39
Inviscid flow over a forward/backward facing step Abhijit Tilak Main CFD Forum 3 February 16, 2005 09:18
