November 8, 2003, 03:15 |
The question I have met!!!
Hi,every guy! When I import the model and mesh geo files generated in cfx4.4 into the Pre of cfx5.6,I have encountered the following error:
ERROR There was a problem importing the mesh from the requested file. The importing process reported the following problem: Hexahedral Element 1183 will degenerate to an invalid element: NodeIDs: 1183, 1184, 1264, 1264, 2488, 2499, 2500, 2488 How can I deal with it successfully?Would you give me the proper means to solve it? Thanks ahead!I expect the answer from you,my friend! |
February 25, 2015, 06:17 |
Thuyavan.Subramani
Rep Power: 11 |
Hai Gukuang,
I do have the same error, when I created mesh in ICEM and tried to import in CFX. If you have found the solution, requesting you to give suggestion. Thanks, Thuyavan.S |
February 25, 2015, 10:27 |
Edmund Singer P.E.
Rep Power: 20 |
Did you generate this mesh in ICEM by extruding a surface quad mesh via rotation around a centerline?
If you did, did you merge the centerline nodes after rotation. Also, I recommend you run Checkmesh in ICEM prior to export, that fixes alot of issues. |
February 26, 2015, 03:06 |
Thuyavan.Subramani
Rep Power: 11 |
Hai,
Thanks for the reply. The model was modelled in CAD software and imported in ICEM. Then mesh is created by converting blocking into unstructed mesh. As I tried to import this mesh model into CFX, I got the same error. If this error is due to import model(STL format). Modelling the model in ICEM, will eradicate the error? Thanks, Thuyavan.S |
February 26, 2015, 08:53 |
Edmund Singer P.E.
Rep Power: 20 |
Geom format plays no issue. It is your mesh buildup that has the issue.
Did you run check mesh? Did it highlight any issues? Usually check mesh will alert you of issues that will cause problems when importing into your CFD code. |
question about uds | tanven | FLUENT | 2 | July 5, 2015 11:22 |
Unanswered question | niklas | OpenFOAM | 2 | July 31, 2013 16:03 |
question about particle track | pengfei | FLUENT | 1 | November 20, 2009 06:33 |
CHANNEL FLOW: a question and a request | Carlos | Main CFD Forum | 4 | August 23, 2002 05:55 |
question | K.L.Huang | Siemens | 1 | March 29, 2000 04:57 |
