Where can the latest warning message be found
Old   November 25, 2003, 21:07
Default Where can the latest warning message be found
zjmjm
When I write the .def file ,present the message:
Error reported from application CFX-Build 5
The definition file has not been written due to inconsistencies in physics options. For the details, see the latest warning messages.
Where can I find the latest waring message?
Old   November 26, 2003, 16:19
Default Re: Where can the latest warning message be found
Hi zjmjm,
Have a look in the journal or session files. Also, it looks like you are using CFX5.5.1, but the current release version is CFX5.6. I recommend upgrading to the current version as the physics processing is now done in CFX-Pre which is a much nicer way of setting the problems up.
Regards, Glenn
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Warning 097- AB Siemens 6 November 15, 2004 04:41
