Where can the latest warning message be found |
November 25, 2003, 21:07 |
When I write the .def file ,present the message:
Error reported from application CFX-Build 5 The definition file has not been written due to inconsistencies in physics options. For the details, see the latest warning messages. Where can I find the latest waring message? |
November 26, 2003, 16:19 |
Re: Where can the latest warning message be found
Hi zjmjm,
Have a look in the journal or session files. Also, it looks like you are using CFX5.5.1, but the current release version is CFX5.6. I recommend upgrading to the current version as the physics processing is now done in CFX-Pre which is a much nicer way of setting the problems up. Regards, Glenn |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
