What is Pitch??
Old   December 20, 2003, 08:24
Default What is Pitch??
Anne
Hi All, I am starting to use the CFX5.6. I need to understand the concept of pitch. The CFD5.6 documentation refers me to the Example on Rotor Stator. I have read and run this but I still do not understand. I have got very little (if not zero) Mechanical Engineering background.
I am running my transient simulation now and I can see pitches increasing with time step but I am not sure of the implication of this. Please help.
Regards Anne
Old   December 23, 2003, 10:14
Default Re: What is Pitch??
JoeCFD
Pitch refers to the circumferential width of a circuferentially periodic domain.
In simple terms, it is the size of the pie slice. A pizza sliced into 10 pieces has a pitch of 1/10, whereas a pizza sliced into 12 pieces has a smaller pitch, 1/12. MMmmm, Pizza :-P
When you run a transient rotor stator problem, the pitch you see increasing is the offset of the domain from its initial location, i.e. how far it has rotated about the axis.
Old   December 23, 2003, 11:04
Anne
Hi JoeCFD, Thanks. You sounded like a trained teacher. That was simple and clear.
Regards Anne
2D Airfoil Centre of Pressure, Pitch Moment and Pitch Moment Coefficient aerospain ANSYS 2 May 4, 2020 20:47
Interface w. Pitch Change: Thcfd CFX 0 December 22, 2010 03:50
Mesh Motion pitch on a hull Seb CFX 1 February 23, 2009 13:04
Pitch Change & interface connections Kumar CFX 2 August 5, 2007 02:57
Yaw and Pitch angle for gasturbflow Haloejsa Main CFD Forum 0 November 5, 2003 15:20
