stream line
Old   January 17, 2004, 10:40
Default stream line
Neser
Dear All, I am in of your help, I have water flow through a nozzle. when I greated the stream line at inlet in CFx5.6 post. However, the prgram did not draw any thing as line or deoplets. I do know why.
note: (The output water from the nozzle should be droplets)
Old   January 17, 2004, 11:15
Default Re: stream line
Jan Rusås
Try to reverse the direction of the stream line or set them to flow in both directions. (If you know why - why then ask )))
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
