March 16, 2004, 08:07 |
Particle simulation in CFX 5.6
Hi
I have a problem with the particle simulation in CFX 5.6. I inject particle in 5 different mass range into a pipe system. But after 1/4 of the pipe lenght the particle track stops. Why is this happing ? Any hints. Regards Jens |
March 18, 2004, 06:57 |
Re: Particle simulation in CFX 5.6
Jens, could be the simultion time of the particls has run out ? There is a time limit in the setup and if the particls are still in the domain when this time limit runs out then they just stop. Check through the GUI's and on particle setup and you will find this, just make it larger and it should solve your problem Bob
CFX steady simulation | gharek | CFX | 1 | April 7, 2010 18:41 |
cfx particle convergence problem | bharath | CFX | 0 | November 11, 2009 08:34 |
CFX particle tracking | Mehmet SORGUN | CFX | 0 | February 4, 2009 13:24 |
CFX diffuser simulation | Ianto | CFX | 8 | November 20, 2008 02:45 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
