RP & RSP for Gas Solid Flow
Old   March 20, 2004, 04:20
Default RP & RSP for Gas Solid Flow
Liwau
Hello everyone,
How to specify the Reference Pressure in the domain and Relative Static Pressure at outlet for a gas-solid two phase flow in a vertical pipe? Thanks.
Liwau
Old   March 21, 2004, 16:31
Default Re: RP & RSP for Gas Solid Flow
Hi Liwau,
Relative static pressure is a simulation variable - that is the simulation gives you that. You might need to specify relaite static pressure at a boundary depending on the type of simulation you are doing.
Reference pressure is the pressure to which the relative static pressures are referenced to. In general you set this to a pressure typical of the simulation, for instance if the pressure of the simulation is all near atmospheric, then set the reference pressure to 1 atmosphere.
Glenn
Gas solid flow in a pipe with 90 bend pandaba FLUENT 0 September 14, 2010 01:43
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Modeling of solid domains in fluent, no fluid flow Satish Perivilli FLUENT 2 December 1, 2005 11:41
flow thru parallel plate with solid heat generater cindy FLUENT 1 October 10, 2005 22:54
Flow through solid cells Julie Polyakh Siemens 1 September 6, 2003 08:18
