Consideration of Hydrostatic Pressure
Old   March 22, 2004, 21:05
Default Consideration of Hydrostatic Pressure
Liwau
Hello All,
Do I need to consider the hydrostatic pressure in the reference pressure of domain for a gas-solid two-phase flow in the vertical pipe?
Thanks a lot!
Liwau
Old   March 26, 2004, 00:47
Default Re: Consideration of Hydrostatic Pressure
Liwau
The vertical pipe has an inlet at the bottom and an outlet at the top. A gas-solid fow in the pipe from the bottom to the top. Bouyancy model should be applied according to the manual due to the big difference between gas and solid. I think there exists a siginifcant hydrostatic pressure drop between the inlet and the outlet, for example, 1e5 Pa. I got the inlet velocities for both gas and sold from industrial operations. Now my questions are:
1. What's the suitalbe reference pressure for this system?
2. How to specify the boudary conditios both for inlet and outlet?
I have already tried many times for different rererence pressures and different boundary conditions based on the tutorials and the manual guidences. Near two months have been past by, unfortunately I still haven't obtained any converged solutions. I am looking forward to your hints how to solve the problem out. Your any reply is higly appreciated.
Liwau
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Hydrostatic pressure initial Field DiegoNaval OpenFOAM 2 April 1, 2010 10:21
vof + hydrostatic pressure ariorus FLUENT 0 August 7, 2009 10:57
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
Hydrostatic pressure in 5.5 Jens CFX 3 August 21, 2002 11:05
