How to increase stack size?
Old   May 9, 2004, 22:05
Default How to increase stack size?
zz
I met a problem when I run a problem with large-size array user fortan in CFX4.4, it is: forrtl: severe (170)rogram exception - stack overflow.
How can I do? I use Compaq visual Fortan 6.0 as a complier. I don't know how to increase the stack size in ForTran when run coomand: runsolve4.
Any help is appreciated.
Old   May 15, 2004, 13:16
Default is quadratic resistance co-efficient a constant
praveen rajaperumal
hello sirs i have a small query for u all. before getting into the queries i will breifly describe the problem this is related to the quadratic resistance co-efficient in a air filter for pressure drop calculation. here in this problem,we have a 3 domains inlet where we supply the mass flow rate outlet where we apply the avg static pressure BC filter where we supply the value of the K (quadratic resistance co-efficient)
my queries are 1. does k for the filter remain constant irrespective of the velocty value at the inlet to the filter.i have gone through the text in cfx help regarding this and found that it does vary with inlet velocity.ur comments on that sir. 2. please send it across,if u have any formula related to k for 3d flow.
with regards praveen rajaperumal cadem,tpil,hyd,india
Old   April 1, 2012, 07:50
Default overflow
christine
yorelchr is on a distinguished road
I know that this post is really old, but I have the same problem and I can't find any help on the net. Did you find the solution for incresing the stack memory?
yorelchr
yorelchr is offline   Reply With Quote
Old   April 1, 2012, 12:55
kingjewel1 is on a distinguished road
If you're using a batch submission then you can always do this:
qrsh -cwd -V -l h_rt=12:00:00 -l h_vmem=3G -l h_stack=2G -q yourserverqueue -pe ib 8 fluent 3ddp -g -pib -sgeup
kingjewel1 is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
