October 13, 2019, 07:01 |
Fluid Solid Interface Temperature
Sasan Ghomi
Rep Power: 14 |
Dear friends,
Would it be a problem if I had different temperature on the solid side and the fluid side of an interface? As per the CFX User Guide, it is probable to have a discrepancy between the above-mentioned temperature. How large could it be? Any idea would be appreciated. BR, Sasan |
October 13, 2019, 18:13 |
Rep Power: 143 |
The control volumes will be at different temperatures on either side of the interface, that is how the heat transfer at the interface is implemented.
Or have I misunderstood you? If so, which temperatures are you talking about?
October 14, 2019, 00:32 |
Sasan Ghomi
Rep Power: 14 |
I mean the interface between the solid domain and the fluid domain has two sides, one of which belongs to the solid domain and the other one belongs to the fluid one. However, they are situated in one place and GGI interface connects these two sides together.
Is there any problem when the "areaAve(T)" reports different temperature for these two sides? Sasan Ghomi BR |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
How to create solid to fluid interface in Fluent using an ICEM CFD mesh. | ekraft | FLUENT | 1 | June 15, 2017 11:59 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
