Error during get surface loads! in cfx
Old   March 25, 2009, 16:01
Default Error during get surface loads! in cfx
Faraaz
cfxuser1 is on a distinguished road
Hi everyone,
I am doing a fluid-structure interaction problem. I am getting this error message in the solver:
" Error during get surface loads: Total Force. Error Message: Read."
I don't understand why I am getting this error. I have run this same simulation before with a slightly different model and it worked. Now after changing the model a little bit, I am getting this error message. The model is basically a beam. The only difference between the two models is that the first one has one end of the beam (the flat face pointing in -x direction) as a fixed support and the second has that same end as a fixed support except for that end is attached to a circular object. So the circular face is a fixed support. i sketched it below so that it easier to understand
ist case:
fixed support>>>>> ----------------------------
2nd case:
fixed support >>>> O----------------------------
Could you please help on this issue.
Thanks
Faraaz
cfxuser1 is offline   Reply With Quote
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
CFX 5.6 the surface overlape itself Neser CFX 0 December 20, 2004 11:13
Can we simulate 3D free surface with CFX? Alan CFX 7 June 5, 2003 12:19
CFX 4.4 New free surface option Michael Rasmussen CFX 3 October 5, 2001 13:24
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
