Hi Resolution Scheme
Old   October 26, 2004, 13:23
Default Hi Resolution Scheme
Craig Johansen
2 Questions:
1) I know that the Hi-Resolution scheme keeps Beta (blend factor) as close to 1 as possible. This keeps the advection scheme as close to second order accurate as possible. How is Beta Calculated? Is it based upon a CFL criteria?
2) I couldn't figure out how to plot the distribution of Beta throughout my solution in CFX post. Is this possible?
Thanks
Old   October 26, 2004, 18:18
Default Re: Hi Resolution Scheme
Hi Craig,
1) beta is calculated on boundedness considerations, not CFL. Have a look at the documentation, page 235, Numerical considerations.
2) You can plot beta in Post. The beta variables will appear as "[variable].beta" under the additional variable list.
Old   October 26, 2004, 20:21
Craig Johansen
Thanks Glenn,
I read the documentation on page 235 regarding beta before I posted the message. It says Beta is calculated to be as close to 1 as possible without VIOLATING boundeness principles. It is not calculated on boundedness considerations, it is just assuring that Beta does not exceed a certain value(3^0.5).
It says the 'recipe' for Beta is given by Barth and Jesperson (1989). I went and got that paper but I still do not know how Beta is calculated.
I am under the impression that Beta is a function of local stability. If the local position in the computational grid is unstable, CFX will decrease the value to Beta applied to that area. If this is true, what stability criteria does is follow to calculate Beta. If it is not based on a cfl number, is it based upon a local cell Reynolds number?
Thanks for the information about Post.
Old   October 27, 2004, 18:57
Hi Craig,
I think you have misunderstood the documentation. Boundedness is different to numerical stability criteria such as CFL. Boundedness refers to keeping the solution within the possible physical limits, such as the temperature of any part of the fluid between a hot and cold plate must be between the hot and cold plate temperatures. It is not physically possible to have a temperature colder than the cold plate, but in a numerical simulation with poor boundedness it can occur.
I have not seen the B&J paper, but if that does explain things adequately, try the textbook "Computational Fluid Mechanics" by Roache. It has an excellent description of the various issues for accurate CFD simulations such as numerical stability and boundedness.
Old   October 30, 2004, 21:06
Neale
Beta is used for the high resolution advection scheme. In that scheme it needs an "upwinded" value of "phi" at integration points:
phi_ip = phi_upwind + beta * r dot grad(phi)
-phi_upwind is determined based on the sign of the mass flow rate at the integration point.
-r is the vector pointing from the upwind node to the integration point.
-grad(phi) is the control volume gradient of phi at the upwind node
For first order upwind, beta =0, for second order beta = 1.
The high resolution scheme calculates beta such that the value of "phi" at the integration point will not create an overshoot or undershoot with respect to the local nodal values.
There must be an equation in the Barth and Jesperson paper that has something like max(..., min(...), etc...) This equation is called a "limiter". The calculation of beta is based on that.
Neale
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
high resolution scheme venkatesh4386@gmail.com CFX 5 April 20, 2014 23:37
[CFD-Post] High resolution scheme blend factor siw CFX 5 May 26, 2011 17:23
high resolution scheme az_f CFX 0 November 24, 2010 22:52
High resolution scheme??? vijay CFX 1 April 22, 2008 09:37
