velocity on no-slip wall
Old   November 2, 2004, 08:03
Default velocity on no-slip wall
freshman
Hi CFXUsers:
In CFXPost,I create a polyline object on no-slip wall and export the velocity on the object.I think the results should be zero because it is on no-slip wall in stationary frame,but it isn't.Could you give me a hint? Thanks in advance.
freshman
Old   November 3, 2004, 04:04
Default Re: velocity on no-slip wall
Jeff
The velocities you are getting are the conservative velocities which map the adjacent internal near wall flow velocity to the wall node. I've done other calculations with the velocities at the wall nodes and that's what I get. When you plot a contour of velocity in a plane or a boundary, Post uses a "hybrid" option which zeroes out all the velocities at the walls for better visualization.
Jeff
Wall function for velocity? johnblund OpenFOAM 3 September 6, 2022 07:22
CFX does not continue Shafiul CFX 10 February 17, 2011 07:57
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
maintaining a logarithmic velocity distribution Morten Andersen CFX 1 January 8, 2007 11:37
slip velocity on boundary (V.P.M) Lee, Juhee Main CFD Forum 3 October 22, 1998 15:30
