How to make surface (for opening) in WorkBench DM
Old   November 11, 2004, 20:23
Default How to make surface (for opening) in WorkBench DM
Coriolius
I have made a rectangular domain and want to add some small rectangular surface to represent the inlet and outlet opening. Making the surface from skeches is possible but it causes error when meshing. Is there any convenient method for making such kind of opening by suface in the WorkBench Design Modeler?
Old   November 12, 2004, 16:23
Default Re: How to make surface (for opening) in WorkBench
Robin
Hi Coriolius,
Select the surface and click on the sketching tab, this will automatically create a plane on your surface. Sketch the area you want and choose Extrude. Under the extrude options, choose imprint face.
This will imprint your sketch onto the faces. How many faces will depend on what depth options you choose. To limit it to the face you are sketching on, choose "To Next" or "To Face" and select the face.
Regards, Robin
[Gmsh] gmsh and boundary layers kanuk OpenFOAM Meshing & Mesh Conversion 11 August 14, 2015 12:35
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
How to make a surface group with CUI yonishi Fluent UDF and Scheme Programming 0 November 28, 2010 04:03
CFX 4.4 New free surface option Viatcheslav Anissimov CFX 0 April 3, 2002 06:27
