Surface orientation in ICEM5..Please help.
Old   November 24, 2004, 04:35
Default Surface orientation in ICEM5..Please help.
Pete
Hi all,
I recently create a tetra mesh with prism elements. When I check the mesh, it said the surface orientation is not okay but when I click on the "Fix", it should me a strange function and said it can't be fixed. A tsl script error pops up later. What can I do to fix this problem? If not solved this error, will that affect the simulation in CFX5.7?
Thank you for your advice. Really don't know what to do right now.... From,Pete
Old   November 24, 2004, 05:52
Default Re: Surface orientation in ICEM5..Please help.
deLuther
This error can affect simulation sometimes, especially when you have internal walls (we had such problems). To fix it you need switch on such families and use ReOrient Mesh->Reorient Consistent (in terms of new gui) for surface elements.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
