November 22, 2004, 14:51 |
FINMES error message!!
I have a fatal overflow error in the FINMES subroutine. Someone can help me? I try to change the resolution method, but donīt work.
November 23, 2004, 07:42 |
Re: FINMES error message!!
Try reducing the physical time step size. Regards James |
November 23, 2004, 11:20 |
Thanks James! I reduce the phisical time step size to 10-5. SO I put to run and did the same error. May I change the size of the mesh grid? Do you know the best relation between the phisical time step and the mesh size? Thanks again. Regards Henry
November 25, 2004, 01:17 |
The appropraite physical time step size is largely independant of the grid. You should use a timescale representative of your problem. If you are still getting FINMES errors in the first iteration then you almost certainly need to reduce the timestep further. Glenn |
December 7, 2004, 23:00 |
Henry,
Many things could be wrong: - Physical timescale may only be part of the problem. Typical rule of thumb is to use a maximum of 1/3 of the fluid residence time in through your device. - Startup difficulties are typically initial guess related. How are you setting the initial guess for velocity and pressure for example?? - Perhaps you are running with turbulence on? Maybe you need to use the zero equation model to get a rough solution, and then restart with k-epsilon?? - Maybe your boundary conditions are too much at startup so you might need to ramp up your inlet total pressure or velocity as a function of iteration As always, many things to go wrong, many things to try... Neale |
December 8, 2004, 04:59 |
Thank you for the help Neale,I will try some changes and see what happen. Thank you again.
FINMES Intermittent Error | CFXman | CFX | 0 | May 23, 2007 04:20 |
FINMES Error - Fatal Overflow in linear solver | Jacob | CFX | 0 | January 10, 2007 08:43 |
ERROR #004100018 has occurred in subroutine FINMES | San Chang | CFX | 1 | May 26, 2004 18:30 |
