Lift, Drag Vs time chart,calculations
Old   February 15, 2005, 06:18
Default Lift, Drag Vs time chart,calculations
Jamesd69climber
Hi
I am interested in calculating the lift and drag coefficients over time for a bluff body.
Is it possible to have such a graph made in post processor or solver, or do I need to calculate the coefficients manually for each timestep?
Regards
James
Old   February 15, 2005, 07:00
Default Re: Lift, Drag Vs time chart,calculations
James Date
You need to create expressions for Cl, Cd and then monitor them in the output menu.
This should give you an idea of what to do.
The expressions go something like this:
LIBRARY:
CEL:
EXPRESSIONS:
Angle = 0 [deg]
Span = 0.1 [m]
Chord = 0.18574 [m]
SectionArea = Chord*Span
Drag = ((force_x()@Section)*cos(Angle))+((force_y()@Secti on)*sin(Angle))
Free Stream = 4.1 [m s^-1]
CD = Drag/(0.5*1027.6*SectionArea*Free Stream^2)
Lift = (-1.0*(force_x()@Section)*sin(Angle))+((force_y()@Se ction)*cos(Angle))
CL = Lift/(0.5*1027.6*SectionArea*Free Stream^2)
CLCD = Lift/Drag
CM = torque_z()@Section/(0.5*1027.6*SectionArea*Free Stream^2)
NormalF = (Lift*cos(Angle))+(Drag*sin(Angle))
CNN = NormalF/(0.5*1027.6*SectionArea*Free Stream^2)
CPX = torque_z()@Section/NormalF
FX = force_x()@Section
FY = force_y()@Section
XTorque = torque_x()@Section
YTorque = torque_y()@Section
ZTorque = torque_z()@Section
uu = Free Stream*cos(Angle)
vv = Free Stream*sin(Angle)
ww = 0 [m s^-1]
END
END
The monitor points go something like this:
OUTPUT CONTROL:
MONITOR OBJECTS:
MONITOR BALANCES:
Option = Full
END
MONITOR FORCES:
Option = Full
END
MONITOR PARTICLES:
Option = Full
END
MONITOR POINT: CLCD Ratio
Expression Value = CLCD
Option = Expression
END
MONITOR POINT: Centre of Pressure
Expression Value = CPX
Option = Expression
END
MONITOR POINT: Drag Coefficient
Expression Value = CD
Option = Expression
END
MONITOR POINT: Drag Force
Expression Value = Drag
Option = Expression
END
MONITOR POINT: Force X
Expression Value = FX
Option = Expression
END
MONITOR POINT: Force Y
Expression Value = FY
Option = Expression
END
MONITOR POINT: Lift Coefficient
Option = Expression
END
MONITOR POINT: Lift Force
Expression Value = Lift
Option = Expression
END
MONITOR POINT: Moment Coefficient
Expression Value = CM
Option = Expression
END
MONITOR POINT: Normal Coefficient
Expression Value = CNN
Option = Expression
END
MONITOR POINT: Normal Force
Expression Value = NormalF
Option = Expression
END
MONITOR POINT: TorqueX
Expression Value = XTorque
Option = Expression
END
MONITOR POINT: TorqueY
Expression Value = YTorque
Option = Expression
END
MONITOR POINT: TorqueZ
Expression Value = ZTorque
Option = Expression
END
MONITOR RESIDUALS:
Option = Full
END
MONITOR TOTALS:
Option = Full
END
END
RESULTS:
File Compression Level = Default
Option = Full
Output Boundary Flows = All
Output Equation Residuals = All
Output Variable Operators = All
END
END
James
Old   February 15, 2005, 07:19
Jamesd69climber
James
Thank you for your reply, most appreciated!
James
Old   February 15, 2005, 08:43
Ogbeni
James, Excellent !, any chance you can define some of the variables ? and some explantion of the commands , for instance what's 1027.6 related to or I am asking too much,
Old   February 15, 2005, 14:25
James Date
You're best bet is to have a look at the CCL guide in the CFX user manual to work out any of the commands which I've used which aren't familiar.
Angle = Angle of Incidence
Span = Span of Section
Chord = Chord of Section
Free Stream = Free Stream Flow Velocity
CD = Drag Coefficient
CL = Lift Coefficient
CNN = Normal Force Coefficient
CLCD = Lift/Drag Ratio
CM = Moment Coefficient
CPX = Centre of Pressure in the x-direction
uu, vv & ww = Flow Boundary Condition Velocities
1027.6 is the density of salt water at 5 deg C.
James
Old   February 16, 2005, 14:29
Akin
James, I am not sure CFX produce a force_x,force_y or z for that matter. Also the statement @section, refers to the wall in question, please clarify.
Old   February 16, 2005, 17:58
James Date
The Statement:
force_x()@Section
Gives the total force in the x-direction acting on the wall defined with the name "Section".
James
Old   February 17, 2005, 09:43
Rui
Take a look at Tutorial 20 page 414 (CFX-5.7 Documentation), where the force on the ball due to fluid flow, FFlow, is defined as force_y()Ball
Old   February 17, 2005, 17:23
Akin
Cheers Janes and Rui
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
