solid particle + water
Old   March 4, 2005, 23:00
Default solid particle + water
Neser
Hi, if I have created a variable compassion mixture. It has created from two materials. The 1st one is a solid particle. The 2nd is water at 25 C. The thermodynamic state of the mixture is defined as liquid. Is this means solid particles are dissolved in the water and created that variable compassion mixture.
If No, How can create an aqueous solution with a certain salt concentration. Also, if no, what is the meaning of thermodynamic state as a liquid however it is two phases liquid and solid.
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Simulating Water Splash Using a Particle System Zi-Wei Chiou Main CFD Forum 0 March 4, 2002 06:33
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
