March 5, 2005, 01:50 |
error on cfx5.7 solver
when i run in solve, there is a error like a circular dependency is detected..........and the problem can be solved by setting expert parameter :stop gradvxb=f'
i want to know how to set it thanks |
March 6, 2005, 16:25 |
Re: error on cfx5.7 solver
Have a look in the documentation under expert parameters. Glenn Horrocks |
March 7, 2005, 05:38 |
hi
go to command line then use cfx5cmds command and create a text file. then scan the text file and look for the column on expert parameter there add the line stop gradvxb=f. before this make sure u have created expert parameter in cfx pre. hope this helps wilson |
A New Solver for Supersonic Combustion | nakul | OpenFOAM Announcements from Other Sources | 19 | February 27, 2024 09:44 |
[Other] A New Solver for Supersonic Combustion | nakul | OpenFOAM Community Contributions | 20 | February 22, 2019 09:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
