Home > Forums > CFX
Working with mixture in CFX 5.7.1
Old   March 12, 2005, 13:06
Default Working with mixture in CFX 5.7.1
Cesar Augusto
Hello:
I want to find a solution with a simple Tmixer that works with Ethanol and Water. These two materials are well known.
When I define the materials and the corresponding boundaries conditions (one inlet for Ethanol and the other for water, one outlet for the mixture) I think I have a problem.
First I defined only these two materials. Then I added a mixture containing the two materials. Only doing this I could work with diffusivity parameter, that I know it is important. But there are other parameters i can't manage well, like interface mass flux, length interface mixing, etc.
The results are not perfect. First off all because the mixing occurrs so fast, even something before the two materials contact each other.
Where might be my mistake???
Old   March 15, 2005, 13:06
Default Re: Working with mixture in CFX 5.7.1
Phil
It sounds like you've set up a multiphase calculation rather than a multicomponent calculation. A multiphase calculation has multiple materials in the 'Fluids List' for the domain, while a multicomponent problem chooses a single material which is a 'Variable Composition Mixture' of other materials. See the documentation for more details on how to set up multicomponent simulations.
Old   March 16, 2005, 13:49
Cesar Augusto
Dear Phil
I use a simulation where a mixture of variable composition is the only one material, composed by Ethanol and Water. For the Inlet 1 through Water come in, the mass fraction of Ethanol has a value of 0.0 and for the Inlet 2 through Ethanol come it has a value of 1.0. That's because in the fluids components of the domain only Ethanol appears, this is surely because Water component was constrained and Ethanol was given a diffusivity value (transport equation).
But when I run the simulation in CFX solver, almost immediately an error was found saying
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Option = Ideal Mixture is not currently supported
It is strange because in a previous simulation the Mixture material was defined as ideal mixture too and the running was OK.
Could you say something about my simulation and give me your comments and better suggestions how to solve the problem.
Thanks
Cesar A.
Old   March 16, 2005, 14:09
Phil
Sounds like you should contact your support rep.
Thread Tools
Trackbacks are On
How to decide interfacial length scale in Mixture Model of CFX multiphase simulation? TommySean CFX 6 April 6, 2012 23:46
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
amd athlon64 cpu and cfx 5.7.1 solver cmete CFX 3 October 20, 2005 22:16
CFX 5.7.1 Ray CFX 2 October 9, 2005 12:10
USRBCS in CFX 5 (actually, 5.7.1) ATS CFX 2 August 24, 2005 12:30
