general momemtum source option - reg
Old   March 28, 2005, 12:01
Default general momemtum source option - reg
Fred
Hello everybody, How the general momentum source option in the subdomain form(CFX5) works? In my case, i know the forces generated by the region that is defined as subdomain in all 3 directions, how to incorporate these forces as source terms(N/m^3) in cfx.When i divide this forces by the subdomain volume and solved, results seems to vary a lot and the behavoir of the this source term is also pretty unclear.Can anyone please help me?
Thanks Regards Fred
Old   March 29, 2005, 07:33
Default Re: general momemtum source option - reg
Atit Koonsrisuk
Dear Fred, As I understand, the momentum sorce term is the force per unit volume in CFX. First you devide the forces that you know by the volume of the subdomain, then you enter them as each component in 'General Momentum Source' of 'Edit Subdomain' dialogbox. I hope it help.
Atit
Old   March 29, 2005, 11:57
Fred
Dear Atit, Thanks for ur suggestion. The force that i gave is the net force generated by the region what i defined as the subdomain, so this force should also change the velocity once it crosses the subdomain. for example,difference in the velocity just upstream and downsteam the subdomain region multiplied by the mass flow rate gives the net force generated by the region that is defined as a subdomain.This force is divided by the subdomain volume and is given as a source term. But the results for the analysis using subdomain doesnt match with the original case.I am not sure why it is happening like this?
Thanks in Advance Regards Fred
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
CFX Parameters Settings Flaky CFX 21 October 28, 2010 18:16
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
particle tracking mike CFX 3 April 17, 2006 00:05
