ICEM TETRA
Old   March 25, 2005, 08:02
Default ICEM TETRA
Ram
When we are using Auto Mesh in ICEM-TETRA, ICEM does not capture the vertices. For example if we have a cube, ICEM is not placing a node at the 8 vertices. How do we ensure ICEM follows the vertices.
Old   March 26, 2005, 16:59
Default Re: ICEM TETRA
Jeff
It's also probably not putting vertices on the 12 edges......
Use Geometry Repair, and select Rebuild Toplogy (the first button). This puts hard edges on your 12 curves and forces vertices there. This is usually the first step when importing a model from CAD.
Jeff
Old   April 22, 2005, 03:47
Charles Shan
when I check the tet mesh, some problems such as multiple edge and non-manifold will occur. I have no idea of what i should do. can anyone give me advices on how to handle them in general?
Thanks in advance! charles
Exporting ICEM Tetra Grid to Fluent with Hexa-Core Tim FLUENT 2 August 30, 2007 07:16
Icem tetra - Running in parrallel? Joe CFX 5 September 9, 2006 12:37
ICEM CFD 5.1 problem with tetra count Baskaran CFX 2 March 13, 2006 12:59
ICEM TETRA - elongated elements Zbynek Main CFD Forum 1 June 28, 2004 16:08
Have you used ICEM CFD TETRA and HEXA ? David Main CFD Forum 1 August 22, 2000 08:56
