Fatal error
Old   April 29, 2005, 11:00
Default Fatal error
Marco Melo
Hi! I'm using CFX-5.6 and I'm having this error: edges do not match for face, can any one help me! I'm simulating a anular space, and the error it's in one of the bottom surfaces.
Thanks
Old   May 2, 2005, 11:35
Default Re: Fatal error
stex_
It depends on the mesh. If you have some "Periodic" boundary conditions, or "interfaces", the faces need to be the same, maybe the top and the bottom surfaces in your problem.
Try to check the mesh
Old   May 2, 2005, 13:34
Marco Melo
Thanks! I'll check it out!
polynomial thermophysical properties II sebastian OpenFOAM Running, Solving & CFD 54 November 21, 2019 07:12
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 06:12
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
