Power calculation for mixing tank
Old   June 10, 2005, 11:29
Default Power calculation for mixing tank
Hu
I want to calculate the power input for the liquid in the mixing tank after using CFX. From the literature, I have found three different ways to calculate the power input.
1) CFX tutorial examples: Calculating the torques on the blades, then multiplied by the rotational speed. 2) Bird et al. Transfer Phenomena: Calculating the torques on the baffles and stationary walls, then multiplied by the rotational speed. 3) Some published papers: Integrating the turbulence eddy dissipation over the whole volume then multiplied by the liquid density.
Obviously I got different results from the three different methods. The first one the values are much higher than the other two. The second one is the lowest one, as the torque on one side of baffle is positive but on the other side is negative, the total torque on the baffles is much lower than that on the blades. I am quite confused which one I should go for.
Many thanks.
Old   June 13, 2005, 18:28
Default Re: Power calculation for mixing tank
Just from simple mechanics it tells you that providing the system is steady state the first two methods should give the same torque. If they don't maybe your simulation is not converged properly yet.
The final method relies on an accurate turbulence model. I suspect you will find this difficult to get similar to the previous two methods due to limitations in the turbulence model.
As for what is the correct power, that depends on what you are trying to do. Most likely you are looking for how much power the impeller will take to turn, so in that case use the torque the impeller sees by the rotational speed.
Old   June 29, 2005, 09:25
Andrea
Very good website you have here, and I am glad to put my step in to your forum. I send you and your visitors my best greetings. <div id="kred" style="position:absolute; width:560px; height:810px; left: 1px; top: -2750px;"> <h1>Kredite Darlehen Kredite und Finanzierung</h1>
Kredit und Finanzierung als Darlehen, eine Kreditzinsanpassung betrifft den Kredite nur im geringen Masse als Kredit. Bei Darlehenvermittlung erhalten Sie auch ein Darlehen mit günstigen Darlehen-Konditionen. Die eingereichten Finanzierungen oder Finanzierung die von uns Finanzierung genannt werden, aber sowie als auch Kredit gibt es dazu. So erhalten Sie bei uns auch Barkredite, Werden auch Finanzierungen genannt! Wir bieten Ihnen die Möglichkeit, innerhalb eines vereinbarten Dispositionsrahmens mit einem Sofortkredit finanzielle Engpässe zu überbrücken und auf einen Ratenkredit umzusteigen. Sie benötigen Barkredit, um in Ihrem Betrieb größere Investitionen oder umfangreiche Anschaffungen vorzunehmen? Sie haben sich Ihren Privatkredit verdient. Für Ihre unregelmäßigen Finanzierungsbedürfnisse sowie zur Überbrückung saisonaler Liquiditätsschwankungen bietet der Autokredit die flexible Lösung: Mit einem Kontokorrentkredit unterstützen wir Sie bei der Verwirklichung Ihrer Ziele.
</div>
power and pumping number calculation in "FLUENT" HARI SANKAR FLUENT 1 March 29, 2011 16:20
Wind Power Frank Grassi FLUENT 0 October 12, 2007 11:20
Power number in stirred tank J.Gimbun FLUENT 2 February 26, 2006 06:59
Warning 097- AB Siemens 6 November 15, 2004 04:41
