Version from 5.7.1 to 10
Old   August 30, 2005, 11:58
Default Version from 5.7.1 to 10
Lucio
Hi, Iīm surprised because the version change from 5.7.1 to 10.0 Is it really, or the other versions appears and I didnīt saw? There is a great difference between them? Thanks, Lucio
Old   August 30, 2005, 13:59
Default Re: Version from 5.7.1 to 10
Rui
Hi, CFX changed from version 5.7.1 directly to version 10. Take a look at http://www.ansys.com/products/newfeatures/fluids.asp
P.S. Does somebody know how I can make a link to a web site work as a link? In the older version of this forum you just had to write it in the message and it would automatically appear as a link.
Old   August 31, 2005, 03:44
MatejK
you can do it like this:
link
so it looks like this:
link
Old   August 31, 2005, 04:39
Jonas Larsson
Seems like I forgot to turn on the auto-hot-link feature when we switched to the new server. I've enabled it again so now you should be able to just type the address here and get it hot-linked automatically.
Here is a test: www.google.com. It should also be okay to type in the full html code like MatejK showed. Here is test if that link to google.
OpenFOAM on cluster: version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found ovie OpenFOAM 10 April 19, 2021 18:06
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
bubbleFoam validation case balkrishna OpenFOAM Running, Solving & CFD 24 August 30, 2010 04:37
version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found ovie Main CFD Forum 1 April 19, 2010 14:00
[OpenFOAM] Problem with paraFoam on a linux-64 bit bunni ParaView 4 April 14, 2010 20:55
