May 22, 2013, 07:11 |
Undeseriable surface in CFX
Yaser
Rep Power: 12 |
hi everybody
i made a cone for inlet of a power turbine with ICEM, after meshing, i read it from CFX, but when CFX read it, in the geometery, I have some unknown surfaces and area that i didn't produce them. i made my geo with various method, but the problem is still alive. of course, i export my mesh from ICEM with Fluent type file, but Fluent cant read it!!!! if anybody know about them, please help me. thanks a lot. |
May 22, 2013, 07:20 |
Rep Power: 143 |
Sounds like a problem with setting up the surfaces in ICEM. I would load the mesh in ICEM and fix the boundary surfaces up.
May 25, 2013, 05:59 |
Yaser
Rep Power: 12 |
thank you ghorrocks, but i dont understand what are you doing, whould you please explain for me more?!
the geometery have no fault in the ICEM, but when read it in the CFX the problem come in. thank you |
May 25, 2013, 07:14 |
Rep Power: 14 |
U should use AnsysCFX as solver for export from icem to Cfx . Why u r using Fluent type file for export
May 26, 2013, 02:42 |
Yaser
Rep Power: 12 |
hi mat
i do this and use CFX solver, but some undesirible surface and area were made on the geometery. Also, when i used the Fluent_V6 solver, the exporting file dont read by CFX and Fluent. thank you |
May 27, 2013, 02:47 |
Rep Power: 14 |
Use AnsysCFX as solver for export in icem and when u import file in CFX pre use ICEMCFD in drop down menu of mesh format. It should work fine.
Also only mesh goes from ICEM CFD to CFX. If u see any undesirable surface in CFX it is geeting meshed in ICEMCFD. Zoom in zoom out fit view to check geometry in ICEM CFD for any unwanted surface. |
May 28, 2013, 03:39 |
Yaser
Rep Power: 12 |
Hi Dear
i do all you say, but the problem is on th etable!!! in ICEM, i draw two curves, then rotate them about an axis, made surface and body, after that i mesh it. anything is ok in ICEM, but i CFX ..... sincerely yours. |
May 28, 2013, 06:13 |
Rep Power: 143 |
And what is wrong with the image you posted?
June 1, 2013, 02:04 |
#9 |
Yaser
Rep Power: 12 |
Hi.
there are a lot of surfaces on the main(s) surface. On the outlet boundary, for example, CFX divide the boundary in two zone, one is, some thing like as orthogonal mesh and one is rest of the boundary. when you want define the boundaries, you must select two or more surfaces for one boundary. |
June 1, 2013, 06:11 |
#10 |
Rep Power: 143 |
This might be just a CFX-Pre display thing or it could be you defined the surface to be patch work like this.
June 9, 2013, 00:02 |
#11 |
Yaser
Rep Power: 12 |
hi
when i want to specify boundary conditions, i must choose two surfaces for one boundary, whereas i have only one surface, and additional surf was created by CFX. in any way, thank you for your attantion. |
June 9, 2013, 23:53 |
#12 |
Yaser
Rep Power: 12 |
do anybody have some idea about this?
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Error during get surface loads! in cfx | cfxuser1 | CFX | 0 | March 25, 2009 16:01 |
CFX 5.6 the surface overlape itself | Neser | CFX | 0 | December 20, 2004 11:13 |
Can we simulate 3D free surface with CFX? | Alan | CFX | 7 | June 5, 2003 12:19 |
