September 7, 2005, 05:17 |
Convergence
Hi, Can the experts here give me their view on what they consider good convergence for engineering flows. The CFX documentation mentions it to be residual RMS=1 E -4. Is this appropriate? Does this change convergence criterion change from flow to flow? Adrian
September 7, 2005, 09:22 |
Re: Convergence
you can check up the following in help: :Solver Modelling :>Advice on Flow Modelling :>>Monitoring and Obtaining Convergence :>>>MAX Residual Level Basically, 1e-4 is said to be "sufficient for most engineering applications", but the convergence criteria depends on the problem geometry and boundary conditions. I would recommend you to make a test on a typical flow problem that you are interested in: just run a few simulations with different residual levels, and check out the dependency of the flow quantity that you are looking for. Taner Baytekin |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
Defect correction and convergence | ganesh | Main CFD Forum | 4 | June 30, 2006 14:20 |
