Icem script error in Workbench environment
Old   September 8, 2005, 05:13
Default Icem script error in Workbench environment
mech80
when I try to launch Advanced Meshing (ICEM) in the Workbench environment (v10.0) it appears a script error window with this message:
|Script Error |Line: 251 |Char: 12 |Error: |Code: 80004005 |Source: |Script: aieobj.LoadAIE( loadCmd,"");
How can I resolve this problem?
Old   September 8, 2005, 09:24
Default Re: Icem script error in Workbench environment
Myron
I've just tried on my system (Windows) and it works fine. Make sure you have installed ICEM CFD (or AI*Environment) v10.0 with WB v10.0.
Old   September 8, 2005, 09:57
test
hi,
the script error is usually encountered due to anti-virus or firewall.
you can try some of the following:
1. Make sure the anti-virus is not blocking the icem script. It would be best if you can get permission to un-install the firewall and anti-virus and see if ICEM is working. IN some machines you may need to re-install ICEM after removing firewall
2. If the above is not true, check ur internet explorer settings. Check if the disable script toggle is switched on in the advanced settings. IN the internet explorer you can go to tools--> internet options--> advanced.
Hope this helps. you can contact your CFX support people who can help you in getting ICEM running.
Regards, test
Old   September 9, 2005, 08:21
mech80
Thanks, i have uninstalled firewall, antivirus, checked "Disable script debugging" in IE, reinstalled ICEM and Workbench, but it doesn't work... My OS is WinXp Pro with Sp2... What can i try now? In Win2k with Workbench 9.0 i don't have this problem...
Old   September 9, 2005, 10:13
test
Well there is a windows XP firewall with XP serice pack 2. You can go to the security sentre through contol panel and diable the same and see if you still get the error.
This should work
Regards, test
Old   September 9, 2005, 10:44
mech80
In control center it's already all disabled, firewall, antivirus... Another suggestion?
Old   September 10, 2005, 07:00
test
Hey,
You should uncheck disable script debugging toggle..
Will get back to u on monday.
Regards, test
Old   September 11, 2005, 02:59
mech80
...nothing, doesn't work...
Old   September 16, 2005, 11:37
mech80
I have formatted and reinstalled the OS and installed Workbench and Icem before installing the firewall and antivirus, for 2 days it works fine (!), and today it appears the same script error and Icem doesn't start..! The only things I have installed after Workbench was Windows Media Player 10 and DivX and Xvid video codec... Why doesn't work? it's maybe some virus, or some IE hotfix? Today I have reinstalled Icem and Workbench, but nothing... Thank you for help me!
Old   September 16, 2005, 12:56
mech80
I have tried to install on another machine with WinXp Sp2 all updated, and it appears the same script error; i think is some Win hotfix that generates this malfunction...
Old   September 19, 2005, 04:00
  #11
mech80
I've found the script, is "aiemainscript.js" in "C:\Program Files\Ansys Inc\v100\icemcfd\win\aiewb\Language\en-us\Pages\scripts", I have tried to reinstall JavaRE, but nothing, doesn't work... What can I do?
Old   September 19, 2005, 18:13
  #12
Contact CFX support with details of the problem. You may have found a bug in ICEM which they can fix.
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 06:50
[ICEM] what does the different ANSYS ICEM and ANSYS Workbench? agungwp ANSYS Meshing & Geometry 8 April 12, 2016 04:51
icem script prad CFX 5 July 23, 2010 16:30
ICEM CFD in Workbench marek CFX 1 February 15, 2008 10:35
Workbench geometry in to ICEM KM CFX 2 December 21, 2007 13:45
