SST Convergence
Old   September 30, 2005, 10:34
Default SST Convergence
new@cfx
I am facing problems in getting good convergence with an SST model. whereas for the same geometry the K-E model converges easily. The expert parameter section in the documentation mentions a parameter tef numerics option which limits the flux in regions of high omega gradient. Could someone kindly clarify what this option does exactly?
Regards,
Old   September 30, 2005, 10:57
Default Re: SST Convergence
Robin
Are you sure your convergence problem is numerical? Quite often, using the SST model will capture boundary layer separation that the k-e model does not. A separated boundary layer results in a detached shear layer, which can be very unstable.
Before looking for an expert parameter, write a sequence of backup files and look for fluctuating flows downstream of separation points. YOu can also try increasing/decreasing the timestep by factors of 10. In some cases a larger timestep will be enough to get rid of the disturbance.
Regards, Robin
Old   October 1, 2005, 02:29
Vikram
Hi Robin, Thanks a lot for that incisive reply. I will be trying that out and I will keep you posted. Regards, Vikram
Old   October 1, 2005, 06:28
Vikram
Hi, The original question was about the tef numerics option. The documentation says that "the k-omega and SST turbulence models give convergence difficulties in areas of high gradients in "omega" , for example at a blunt trailing edge or sudden rearward facing step, in conjunction with a highly refined boundary layer grid ( generally resolved into the viscous sub-layer). In such situations a flux limiting numerics implementation can be used for the omega equation, activated by setting this parameter to 1."
So what does this flux limiting implementation do exactly? Can someone kindly enlighten me on this ? Robin?
Thanks in advance, Vikram
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
convergence problem of the SST and RNG k-e model for mixing tank ziyan7 FLUENT 0 March 8, 2011 06:13
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Convergence issue in SST for Porous model Raj CFX 0 May 2, 2008 02:43
