how to input 2D model into CFX5.7 by using icemcfd
Old   September 23, 2005, 05:43
Default how to input 2D model into CFX5.7 by using icemcfd
yflin
how to input a 2D model into CFX5.7 by using icem cfd. Please help me.
Old   September 28, 2005, 10:25
Default Re: how to input 2D model into CFX5.7 by using ice
Ho
Hallo. As I know, use " output to CFX " which is on the toolbar, i.e. last item. Also, you need to mesh your model before output to CFX Prepro.
Old   September 29, 2005, 21:46
longbow
Before you do that, you need to extrude 2D mesh in the third direction with one cell. For example, if you 2D mesh is on XY plane, you need to have cell in the Z-direction. CFX can't take a 2D mesh.
Old   September 30, 2005, 04:40
Ho
Hallo,
I draw a 3D hollow divergence nozzle with ICEM 4.2. Then I use Tet Mesh to mesh my structure. However, when I tried to write the file to CFX 5, an error messag, " running ICEM CFD/ CAE Interface vers. 4.2.6 "and extra arg: **.msh happened. what did that mean? Is the file after meshing file. msh or file.uns. and when I tried to import mesh from ICEM in CFX pre., it showed that the format is not compatible with CFX. What is wrong? Thank you .
Old   October 1, 2005, 10:54
longbow
Even though you output mesh into CFX-5 format in ICEM, you should bring it into CFX-Pre as "ICEM CFD" format. When I use Hexa 5.1 and write file to CFX-5, the default file is called "cfx5" without any extension. The latest release of ICEM will create a gtm file.
gamma-ReTheta turbulence model for predicting transitional flows FelixL OpenFOAM Programming & Development 123 August 30, 2022 11:50
Evaporation model in ansys Fluent 12.1 oldisbest Fluent UDF and Scheme Programming 12 March 26, 2020 09:11
simulation results for k-w model and SST model Li CFX 7 June 29, 2007 04:19
Kato-Launder model sam Main CFD Forum 13 September 21, 2006 10:15
