No fluid panels available
Old   October 6, 2005, 06:32
Default No fluid panels available
Andreas
Hello everyone,
I'm working on a model to simulate the flow in a condenser, so I have to create several materials: WaterLiquid, WaterSteam and Air. After creating the fluids they appear in the physics library. I'd also expect them to appear as a seperate panel in the Edit Domain window, when creating a new domain to specify their physics. But the only panels available are General Options, Fluid Models and Initialisation. Can anyone tell me why I can't access the material panels. Thanks in advance
Andreas
Old   October 6, 2005, 08:45
Default Re: No fluid panels available
Robin
There is no materials panel. You can select your material on the General Options panel where it says "Fluids List".
-Robin
Old   October 6, 2005, 09:18
Andreas
Unfortunately I can't select the created materials cause they are not given in the fluid list, even if I open the Selection Dialog Box by clicking the ... icon. I checked all Fluid Domains for it. The fluids appear in the physics library and in the materials panel though.
Old   October 10, 2005, 06:51
test
The reason may be that you have not defined some crutial properties for the material like its viscosity/density/Cp/k
If the material is a solid and you want to use it in eulerian framework, you need to define the material as solid and also define its viscosity (1e-12 )
Regards, test
Old   October 11, 2005, 07:10
Andreas
thanks a lot. at least I can select it in the fluid list now. although i'm still confused why no seperate panel will appear in the edit domain window. in tutorial 9 on page 207-208 for example 2 extra tabs are supposed to appear after creating the matereals "sand fully couples" and "sand one way coupled". when i do the tutorial they are just not available.can anyone tell me why?
Old   October 11, 2005, 12:24
Robin
The extra panels appear for multiphase options if you select more than one fluid in the general options tab.
-Robin
Old   October 12, 2005, 05:20
Andreas
Thanks to Robin and test. You helped me a lot. After selecting all my created materials using the ctrl key everything is as I want it to be.
Old   October 12, 2005, 20:47
Robin
Good. Glad to be of help.
-Robin
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Intl Conf Computational Methods in Fluid Power Jacek Stecki Main CFD Forum 0 November 10, 2002 05:49
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
