airflow separation at a wing section
Old   October 26, 2005, 05:23
Default airflow separation at a wing section
andrew
Does anybody have an idea how to visualize separation at a wing section?
Old   October 26, 2005, 06:32
Default Re: airflow separation at a wing section
DAK565656
Separation or transition? It's easy. Plot velocity vectors near the trailing edge of section
Old   October 27, 2005, 03:42
Michael Bo Hansen
Create a contour with three levels ranging from -1000 to 1000 m/s on the axial velocity. Two colors will appear, above and below zero. Negative values is maybe what you are looking for? kind regards
Old   October 27, 2005, 10:03
andrew
Thank you Michael. I actually have been expecting to see something that visually resembles vorticity due to separation . Anyway that you.
Andrew
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
3D mesh for transient flow around wing section? Nixmich Main CFD Forum 5 January 5, 2011 03:00
plot pressure distribution on a section of 3D wing ROOZBEH FLUENT 3 April 21, 2008 03:30
making wing section cuts in Fluent? mimi FLUENT 0 May 8, 2007 03:42
pressure on duct (axisymetric wing section) Mike Spears FLUENT 0 August 3, 2005 11:53
