No gui for cfx-pre and post
Old   October 26, 2005, 23:01
Default No gui for cfx-pre and post
ali
Hi all, I use two versions of cfx on my machine. Windows version and another one operates linux from ssh node. I must operate exceed to see CFX-pre or launch. I cannot see GUI in cfx-pre or cfx-post for linux version. I see them in windows version. Does anyone know a solution? thanks ali
Old   October 28, 2005, 06:50
Default Re: No gui for cfx-pre and post
Ram
Did you use -X at the end of the command when you start SSH ? e.g. ssh -l usr .. -X -X stands for importing display
Old   October 30, 2005, 19:12
ali
HI Ram, I log into SSH from windows node. I operate SSH for windows. Ali
Old   November 5, 2005, 01:17
Jeff
1. from the linux machine you have to set the DISPLAY environment variable to your machine
setenv DISPLAY mymachinename:0.0
This will bring the GUI up.
2. The graphics viewer, however doesn't come up by default with just Exceed. It tries to use OpenGL to display the viewer, and you will need Exceed3D also. Alternatively, you can run pre and post from the command line using the mesa graphics switch (see cfx5pre -help for exact syntax). It's slower, but works if you don't have Exceed3D.
3. Under the Exceed protocols you will also have to toggle on the GLX extensions to use the OpenGL calls (instead of mesa)
SuSe Linux also needs the latest Exceed (10?) which has the latest GL extensions or it won't work properly.
Hope this helps, Jeff
Old   November 5, 2005, 14:08
ali
Thanks Jeff.. It's very helpful ali
different CFX Pre and Post mesh region mactech001 CFX 9 April 11, 2010 21:08
Objects in PRE and POST ? Felix CFX 0 January 16, 2008 15:53
clarification in LS Pre post David Main CFD Forum 0 July 19, 2007 13:02
Instable Post, Pre and Build Pascale Fonteijn CFX 5 December 23, 2003 06:31
PRE and POST processing package Astrid Barros Main CFD Forum 6 November 16, 2000 10:31
