Water vapour condensation in CFX-5.7.1
Old   October 24, 2005, 08:50
Default Water vapour condensation in CFX-5.7.1
hdj
Hi
I'm trying to simulate water vapour condensation on surface. I've modified boiling_water.ccl in /etc/model-templates. But condensation seems not start. I've tried various Nu, boundary conditions (wall temperature) etc. with no success. Boiling itself is quite good calculated. Has anybody some experience on this? I am using CFX-5.7.1. Any suggestion will be appreciated.
Below is an example of the model.
Best regards.
NuL = 6
NuV = 2000
Pref = 1.014 [bar]
Tsat = 100. [C]
Tdown = Tsat-20 [C]
DOMAIN: boiling device
Coord Frame = Coord 0
Domain Type = Fluid
Fluids List = Water at 100 C,Water Vapour at 100 C
Location = Assembly
BOUNDARY: OUT
Boundary Type = OUTLET
Location = OUT
BOUNDARY CONDITIONS:
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Average Static Pressure
Relative Pressure = Pref
END
PRESSURE AVERAGING:
Option = Average Over Whole Outlet
END END END
BOUNDARY: SYM
Boundary Type = SYMMETRY
Location = SYM1,SYM2
END
BOUNDARY: UP
Boundary Type = WALL
Location = WALLU
HEAT TRANSFER:
Option = Fluid Dependent
END END
FLUID: Water Vapour at 100 C
HEAT TRANSFER:
Option = Adiabatic
END
WALL INFLUENCE ON FLOW:
Option = No Slip
END END END
FLUID: Water at 100 C
HEAT TRANSFER:
Option = Adiabatic
END
Option = No Slip
END END END
WALL CONTACT MODEL:
Option = Use Volume Fraction
END END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
REFERENCE PRESSURE:
Reference Pressure = Pref
END END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Homogeneous Model = False
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = Laminar
END END
FLUID PAIR: Water Vapour at 100 C | Water at 100 C
INTERPHASE HEAT TRANSFER:
Option = Two Resistance
FLUID1 INTERPHASE HEAT TRANSFER:
Fluid1 Nusselt Number = NuV
Option = Nusselt Number
END
FLUID2 INTERPHASE HEAT TRANSFER:
Fluid2 Nusselt Number = NuL
END END
INTERPHASE TRANSFER MODEL:
Option = Particle Model
END
MASS TRANSFER:
Option = Phase Change
PHASE CHANGE MODEL:
Option = Thermal Phase Change
Saturation Temperature = Tsat
END END
MOMENTUM TRANSFER:
DRAG FORCE:
Option = Schiller Naumann
END
LIFT FORCE:
Option = None
END
VIRTUAL MASS FORCE:
Option = None
END
WALL LUBRICATION FORCE:
Option = None
END END
SURFACE TENSION MODEL:
Option = None
END END
FLUID MODELS:
Option = Thermal Energy
END
MORPHOLOGY:
Option = Continuous Fluid
END END END
FLUID MODELS:
END
MORPHOLOGY:
Mean Diameter = 1 [mm]
Option = Dispersed Fluid
END END END
MULTIPHASE MODELS:
Homogeneous Model = Off
FREE SURFACE MODEL:
Option = Standard
END END
BOUNDARY: DOWN
Location = WALLD
HEAT TRANSFER:
END END
HEAT TRANSFER:
Fixed Temperature = Tdown
Option = Fixed Temperature
END
Option = No Slip
END END END
HEAT TRANSFER:
END
Option = No Slip
END END END
WALL CONTACT MODEL:
END END
BOUNDARY: IN
Boundary Type = INLET
Location = IN
FLOW DIRECTION:
Option = Normal to Boundary Condition
END
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
END
MASS AND MOMENTUM:
Option = Total Pressure
Relative Pressure = 1.001*Pref
END END
HEAT TRANSFER:
Option = Static Temperature
Static Temperature = Tsat
END
VOLUME FRACTION:
Option = Value
Volume Fraction = 1
END END END
HEAT TRANSFER:
END
VOLUME FRACTION:
Option = Value
Volume Fraction = 0
END END END END ENDEND
Old   November 27, 2005, 07:15
Default Re: Water vapour condensation in CFX-5.7.1
MAHMOUDI
hello I am interesting in the condensation in the presence of non condensable gases...I want to use CFX in the modeling of the condenser, any help or cooperation is welcome. I am not a professional in the field of CFX or Ansys. thanks
Two-Phase Condensation Case turbo CFX 12 May 2, 2013 20:48
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Condensation of water if humidity > 100% via UDF Wikie Fluent UDF and Scheme Programming 0 November 9, 2010 16:41
air and water vapour mixture - multiphase model Saba FLUENT 0 February 10, 2009 12:05
air and water vapour gianni Siemens 2 January 17, 2005 03:15
