results for both transition and transition free
Old   November 21, 2005, 08:22
Default results for both transition and transition free
krishna
Hello friends i have this problem...
as i doing computations for my work , the results for Transition free and Transition are comeing exactly same... as they r not supposed not for my model. i am doing simulations using cfx-10,for my SST turbulance model and Mach 0.3.
why i am getting same results? what are the points i need to consider for it while running simulations?
please give me some information.....very much urgent
Thanks a lot Hari krihna
Old   November 23, 2005, 19:52
Default Re: results for both transition and transition fre
Mike
Take a look at the variable "Turbulence Intermittency" in CFX-Post; 0 = Laminar, 1 = Turbulent. Do you have any Laminar boundary layers? If you don't see any Laminar boundary layers then check your mesh to make sure you have YPlus = 1 or less. If you don't see the variable "Turbulence Intermittency" then you are not running the transition model correctly. Check that you picked the Gamma Theta option when picking the Turbulent Transition model. Regards, Mike
Old   November 27, 2005, 08:56
krishna
thanks for your info mate...i am doing it now..
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
Where can I get a free software with e^N method for transition prediction? peter.zhao Main CFD Forum 4 January 4, 2010 09:28
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
to LANGTRY ROBIN :help, hypersonic transition SST ben akih CFX 0 September 21, 2006 04:59
Has anyone successfully used transition modell..p2 PetrK CFX 12 May 26, 2006 16:27
