pls help.How to do thisblade passage analysis ???
Old   January 19, 2006, 08:54
Default pls help.How to do thisblade passage analysis ???
kaen
Hi i am doing flow analysis of single blade passage .I am using folowing strategies but nothing works.pls help me in this regard.Total Pressure at inlet is 2.83 bar,Total temp =923 K inlet flow velocity=125 m/sec.Out totoal pr=1.12 bar.,total temp=760 K,Velocity=125 m/sec.rotational speed of passge=60,000 rpm (6280 rad/sec).mas flow =0.596 kg/sec.What i am doing is first giving less rotational speed and when it converges increases speed in next run by taking initial file of prevouis. (1)when i am giving inlet pressure and outlet poressure wit h steady condition and speed as 100 rad/sec.the flo w is cinserved.but real mass flow at inlet and outlet is not achived. it is in terms of thousands insread actual valkue 0.596 kg/sec. (2) when i am giving unsteady solutuion directly without doing steady solution then it says divergence detected so pls tell me which boundary conditon shouls be applied.also shoud i first do steady analysis and then transient analysis.or directly unsteady analysis. thanking u all.
i need help following problem pls pls help gmani CFX 4 March 31, 2009 09:39
how to d othis blade passage analysis ?pls he kaen Siemens 2 January 24, 2006 05:41
pls help.How to do thisblade passage analysis ??? kaen FLUENT 0 January 19, 2006 08:54
how to do blade passage analysis of turbine? kaen FLUENT 0 January 17, 2006 22:49
how to do this blade passage flow analysis ? manish CFX 2 January 16, 2006 03:58
