How to input transient pressure data as BC in pre?
Old   February 3, 2006, 02:38
Default How to input transient pressure data as BC in pre?
User
Hi.. I have two column of experimental data: time t & transient static pressure P(t) stored in a csv file. I wish to use P(t) as my outlet boundary condition in transient simulation.
However, I failed to initialise these data in Pre V.10.
I get an error message when I use "initialise profile data":
Invalid format .... ....unrecognised heading ....expected to read.... [spatial fields] section headings
Can anyone give me some ideas how to input the transient pressure data to Pre so that I can specify P(t) at the outlet BC.
Thank you for your help.
Old   February 3, 2006, 06:42
Default Re: How to input transient pressure data as BC in
Camilo Costa
Exist in CFX help one tutorial that explain this, but i fogive was that!!
forgive my bad english!
Old   February 3, 2006, 09:00
User
Hi Camilo,
I found 5 (CFX 10) tutorials that talk about transient simulation.
Tutorial 4:Flow from a circular vent
Tutorial 6:Buoyant Flow in a partitioned cavity
Tutorial 12:Flow in an axial rotor/stator
Tutorial 17:Air Conditioning simulation
Tutorial 20:Fluid Structure Interaction and Mesh deformation
Tutorial 4 use formula ExpFunction to express transient term and do not use data imported from a text/csv file.
Tutorial 6 seems to use a fixed value for BC.
can't find any relavant info in Tutorial 12 as well.
Tutorial 17 uses the user subroutines ect but I can't find any methods to input t & P(t) from a csv file and use them for boundary condition.
I can't find any relavant info in Tutorial 20 either.
Did I miss out anything in tutorial? Would you mind to tell me which tutorial has the information I need? I have already spend hours to hunt for it.
Thank you very much.
Old   February 3, 2006, 11:33
Camilo Costa
I will sugest this!!
go in expressions anda set this example:
"2*sin((t/1[s]))[Pa] + 415[Pa]" ---> (CALL THIS VP)
clic in plot and define of 0 at 10s.
The pressure varable with time.
Go to bonduary condition that have inlet or outlet and clic in "Enter Expression" and put the name "VP"
Old   February 6, 2006, 01:15
Chirag Jayswal
Check following thread replying to similar query.
http://www.cfd-online.com/Forum/cfx_...cgi?read=12825
Hope this helps.
Kind regards,
Chirag
Transient simulation (Problem with massflow and Pressure) ChristianF CFX 4 August 22, 2011 21:42
how to give pressure as an input in spray modeling satish Siemens 3 March 7, 2008 20:33
how to handel transient data with less file space steven CFX 2 October 27, 2006 17:01
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
