February 3, 2006, 12:03 |
Please Help which model should I use
I am doing the steckler experiment by using CFX. when i use the k-ε model, the central fire location is ok, but the result of corner location is quite different from the steckler experiment. i am quite sure my other setting is no problem.
My question is which model can i use except the k-ε model. Any other recommendation can give me. thx |
February 13, 2006, 05:14 |
Re: Please Help which model should I use
k E is no good near walls try using kW or SST
February 13, 2006, 12:54 |
I had tried the k omega and SST model. The can't had a good resul. I tried the BSL renold stess, it gave a perfect result, but when i changed the door size, some door size cases were very bad. i dont know what happen.
recently, i tried the omega renold model, it gave the result is ok but not accuracy. i had tried a hundred times in this experiment. what can i do to make it better. |
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 04:41 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 10:27 |
