Batch Processing of Meshes
Old   February 13, 2006, 10:04
Default Batch Processing of Meshes
KBanks
Hi all,
Does anyone have experience of gridding lots of geometries in an automatic batch fashion? I can get Turbogrid to work, but not consistently without intervention (I'm gridding turbine blades). Has anyone done this with ICEM Tetra for instance? Is it possible with CFX Mesh?
Thanks for any assistance,
Kevin
Old   February 14, 2006, 02:25
Default Re: Batch Processing of Meshes
CFDworker
Hi Kevin, You can use replay scripts in ICEM. I use for for hexa-meshes, but I don't see why it should not work in tetra. It is however important that you use topologically similar geometry files, since the numbering of points, curves and surfaces needs to be identical in order to make the replay script work.
You start up the replay script from the file menu.
The replay script can be opened and edited in a text editor. If something for some reason does not work, I have had success loading one line of a time in the script, and then sorting the errors out one at a time.
Best regards CFDworker
[General] [Paraview] Batch processing and screenshots saves. el douco ParaView 0 April 9, 2008 03:37
batch processing alireza Main CFD Forum 0 January 11, 2008 11:25
Batch Processing and auto-save option Vimal FLUENT 4 May 17, 2006 14:07
How to do batch processing for CFX Badrinath CFX 9 February 17, 2006 02:55
Help: Batch file for Parallel Processing ( 2CPU ) SC FLUENT 1 July 15, 2003 21:34
