March 4, 2006, 15:16 |
Modeling
I have a geometry with a 'main' inlet and two 'side' inlets, an outlet and 2 vents. The 'main' inlet is held at a pressure of 1000 Pa. The two 'side' inlets are at pressure of P1 and P2. The vents are open to atmosphere. I want to plot my outlet pressure vs P1 and P2. But I know nothing about my outlet BCs. I couldn't calculate the mass flow rate through my outlet because of the complicated geometry. Can anyone help me with this issue? And I also don't understand if I have applied a pressure of 1000 Pa, but I observed pressures of upto 10^5 Pa in post-processing. And some negative presure values also. Can anyone explain to me what does that mean or why is that so? Thanks, Ruchi |
March 6, 2006, 07:59 |
Re: Modeling
Did you specify pressure values with respect to default reference pressure of 1 atm?
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 11:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
Solid Modeling | Chris | Main CFD Forum | 10 | July 2, 2002 07:12 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 09:21 |
Extrusion Modeling | Elliot Schwartz | Main CFD Forum | 1 | September 11, 1998 19:08 |
