analyse heat distribution inside an enclosure |
March 19, 2006, 21:45 |
hello everyon!!!
I would like to know can cfx be used to analyse heat distribution in a volume? If yes, how can i do it? My case is discribed as follow: I have a rectangular enclosure with a rectangular pcb inside. I have redesigned the enclosure and now would like to know if the heat distribution inside the redesigned-enclosure will cause problems. I know it may be an easy problem with a number of steps, but i really do not know how to do it. Can anyone kindly teach me how to do it? Just some brief steps to me are also ok. Thanks everyone. |
March 20, 2006, 09:54 |
Re: analyse heat distribution inside an enclosure
Is your volume of interest solid? Then I believe you simply set this volume asa solid domain, use interfaces to the surrounding fludi domain. COnjugate heat transfer is then automatically calculated.
March 21, 2006, 11:40 |
Sounds like you should be using FLOTHERM or ICEPAK
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Mesh of a model inside an enclosure | lhyue | ANSYS Meshing & Geometry | 2 | October 5, 2010 17:31 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Modelling the Heat flow inside the curing oven | Marios Vlad | CFX | 1 | February 6, 2008 07:11 |
maintaining a logarithmic velocity distribution | Morten Andersen | CFX | 1 | January 8, 2007 11:37 |
