Jet penetration problems
Old   May 4, 2006, 10:40
Default Jet penetration problems
Ahmad
I am running a cold jet simulation from a round inlet and I'm having problems with the penetration of the injected gas in the computational domain. The domain consists of a 5 degree-wedge of a cylinder having a height of 150 mm and a radius of 30 mm. The radius of the inlet is 0.55 mm. The injected gas is CH4 (P=3 atm T=300 k) and the domain is initialized with air (P=1 atm and T=300k). For the boundary conditions, I'm using a pressure subsonic inlet, symmetry for the front and back surfaces and openings for the remaining surfaces. My results are less by a factor of 10 than the experimental and correlated data sets. My objective is to collect the mixture fraction (and its variance) of the injected gas. Any advice is highly appreciated. Thank you.
Old   May 5, 2006, 02:35
Default Re: Jet penetration problems
Joe
Did you check the classic questions?
Old   May 5, 2006, 11:36
Ahmad
I didn't get it. what do you mean? My main problem is that the jet is not penetrating enough in the domain... I might have forgotten to set some paramaters or missed some important details, especially concerning compressibility. is it controllable or is the solver set by default to deal with compressible flows?
Old   May 5, 2006, 12:13
Quest
Maybe set the reference pressure to 0 atm. if its 1 atm every pressure level you set is 1atm more.
Old   May 5, 2006, 12:17
Ahmad
My reference pressure is 1 atm. Given a pressure ratio of 3/1, the relative pressure of the injected gas (CH4) is 2 atm and the initial pressure in the domain (consisting of Air at t = 0 s) is 0 atm.
Old   May 6, 2006, 07:22
dh
You will be running incompressible flow by default. To turn on compressibility, you should enable the Total Energy model. You need to use materials that are set up as an Ideal Gas or Real Fluid. You may also model compressible flow for a General Fluid whose density is a function of pressure.
Old   May 6, 2006, 11:51
Ahmad
In my simulation, the "Total Energy" option is enabled in "Fluids Models" and the viscous work term is included. About modelling a compressible flow with density being a function of pressure, how is this done? Thanks...
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
Jet fan and Tunnel simulation ahlo7 CFX 9 November 13, 2019 04:54
2D Plane Jet Fluent Solution doug Main CFD Forum 11 February 4, 2019 09:34
Angle problems jet imipngement problem ICEM rskrishna87 ANSYS Meshing & Geometry 2 May 24, 2011 15:01
Low temp. (~ 300 K) turb. jet & JANAF problems bart_weisser OpenFOAM Running, Solving & CFD 0 February 11, 2010 18:50
